RCU Forums - View Single Post - G-202 split flap configuration
Old 07-22-2002 | 01:58 PM
bobi
Default G-202 split flap configuration
if you are worried about take off and landings and need flaps....since you already operate 2 servo ailerons you might as well program them to be used as flaps also.
since you cut out aileron to make some flaps now you will need a lot of aileron travel to create same effect as before. ( need more servo travel and you would be needing to use high rates to get required effect)
bobi
