Will This Work???
I am just finishing up my U Can Do 46 and am ready to put in the servos and begin programming. I have never had a plane with a separated elevator so I am not sure exactly how I should set this up on my transmitter. I am using a JR8103 with an R700 receiver. I am installing a 'y' harness on the aelerons and am wondering if I can do the same for the elevator? I know that I have seen that you can use a 'reverse' y harness for other things and would like to know if this would work for the UCD? If it does fit the bill is there anything that I should be aware of in setting up the plane this way? I talked to the hobby shop and they recommended putting the elevators on separate outlets like I have done on aelerons on other planes. Just wondering what you all recommend?
