RCU Forums - View Single Post - BME Edge?
Thread: BME Edge?
Old 07-28-2004 | 11:19 PM
  #153
ronk1
My Feedback: (25)
Default RE: BME Edge?
All of you that jest received or are going to the BME Edge. The covering below the wing that goes at a 45ยบ to the bottom has jest enough to cover. Do not use a heat gun before you check it out and make sure the edge is sealed. It took me some time to correct the problem. An other 1/4" of covering would have been nice. Other then that all is well. --------------------------------------------------As for the rudder, the BME's is taller and Wild Hare is longer. Why; who knows but the BME's is proportionally the same as a 35% Carden.
