i meant I'm not sure it has a curve persay, but to get all things right the top of the wing is flat, the dihedral is made by the angle on the bottom, it shouldn't matter if this is straight or curve flying wise, if the top of the wing is flat then due to the excellent CNC work the bottom WILL!!!!! be right.
Same section but it morphs in thickness.
unless it's the FF wing
