pattern motor os 140 or webra 1.45
Hello there,
I have a Webra 1.45 in my Hydeout and I love it. It has tons of power and is very reliable. I was a little skeptical at first (I don't know why) but I am very glad that I picked up this engine. Not only is it cheaper than the OS, but it is a little better engine in my opinion. The Webra is a little bit bigger, but it has more power, weighs less and costs less. They are both very high quality engines, but if you want more bang for your buck, I would go with the Webra.
Here are the specifications that I got off of the Tower Hobbies website and the Piedmont Models website. They are for the OS 1.40 RX (NOT the injected version) and the Webra 1.45 Aero X respectively. I would not reccomend the injected version of the OS 1.40 because the injectors go bad quite frequently, and I have seen this first hand many times. This is just my opinion, however, and I hope that this helps.
SPECS:
Displacement: 1.40 cu. in.
Bore: 1.26" (32mm)
Stroke: 1.13" (28.6mm)
Practical RPM Range: 1,800 - 10,000
Max Power: 3.5 BHP at 9,000 RPM
Weight (WITHOUT ANY EXHAUST): 29.3 ozs (840g)
Suggested Prop Sizes: 15X14, 16X14
Price: $499
Specifications:
Displacement = 1.45 cu in
Horsepower = 3.95
Bore = 1.23 in
Stroke = 1.22 in
Weight = 28 1/4 oz
RPM Range = 1800-9500
Props (typical) = 16x14, 17x12, 18x10
Price $395
