RCU Forums - View Single Post - Dihedral on a 4*60
Old 07-23-2002 | 11:05 PM
Rcpilot's Avatar
Rcpilot
My Feedback: (78)
Default 4*60 mods
I would take some of the dihedrahl out- about half as much as the plan recomends is good- as others have suggested.
Here is my other suggestions:
Reinforce the landing gear block A LOT!! it is terribly weak--add some larger Triangle stock and then glass it.
DOUBLE the size of ALL control surfaces- ailerons included
Put a 120 4-stroke or a hot 91 2-stroke on it for power.
Use Robart hinges or something besides those cheap CA hinges- if your gonna put this plane through a lot of hard flyin; you'll be happy with stronger hinges.
Pull-pull rudder
I like to cut the canopy down to almost half it's original size- makes the nose of the plane look longer- kinda like a warbird.
It's a great plane to fly-- have fun with it.
