RCU Forums - View Single Post - which one is the best 3d from those ?
Old 07-30-2004 | 03:24 AM
Spacey's Avatar
Spacey
Default RE: which one is the best 3d from those ?
ORIGINAL: lamborghini
just for comparation in my head, you would say the cap can do a little less good 3d than this : http://www.espritmodel.com/l_giles2023d.html or they aren't in the same level at all(the giles is better).
and if we are comparing this two so where is the widebody stand next to them ?
anyway thanks for your help.
The Giles on that link is the China Model Productions Giles right? We have a couple of them flying at our field and I had a chance to take the sticks of one a while back. None of them have been set up for 3D flying so I can not give you a true answer but I can tell you this much the plane has a good feel to it. The one I flew needed a bunch more tail weight. And a lot more throw on the elevator and ailerons. A couple of mixes would have helped to. Some spoilerons in particular for the upright harriers. BUT! I was able to hover it fairly easily DOD and walls were very easy. Upright harriers were easy in my opinion but there was some wingrocking which I think a little bit of spoileron mix will take out. Rudder authority is pretty good and knife edge loops were very easy. It does couple a bit but no headache.
As I said the plane has potential but personally I would not buy one. I'd rather stick to my profiles which I know for a fact are capable.
