which one is the best 3d from those ?
which one will do 3d better. i know they are not 3d monsters but still.
http://www2.towerhobbies.com/cgi-bin...?&I=LXCZR8&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXJ578&P=0
http://www2.towerhobbies.com/cgi-bin...?&I=LXLP44&P=0
http://www.camodel.com.ar/Ingles/wide40ingles.htm
thanks
thanks
I'd say the WideBody 40.
The Ultrasport and Giles need major modification, and even then I don't know how good they would be.
The Cap does 3D (I have one) but the coupling on knife edge does not make it the best flier. Does nice walls though.
i thought the ultra sport will be good because i read there that he can do 3d and it has big control surface.
the widebody 40 is better than the cap ?
how is the cap ? in realflight he doesn't do 3d well so is it diffrent from realflight ?
Real flight does not 3D well, it is nothing to do with the Cap.
the Cap is not the best, though lack of torque roll ability is more due to size (and me). Does snaps and spins well, harriers are quite stable with a bit of spoileron help.
As I say the biggest issue is the rudder coupling. You can elimiate the roll coupling by using less dihedral, but the pitch coupling is quite strong as well I have found. This makes rolling circles etc harder than they should be, let alone knife edge.
To be honest I have not seen either the Ultra Sport or Giles (GP kits are not available in the UK [:'(] had to get the Cap as a special order). Of the two I would go for the giles.
just for comparation in my head, you would say the cap can do a little less good 3d than this : http://www.espritmodel.com/l_giles2023d.html or they aren't in the same level at all(the giles is better).
and if we are comparing this two so where is the widebody stand next to them ?
anyway thanks for your help.
i also wanted to ask, you said you have the cap, would you say he can be a good first 3d plane which can also be a mini imac plane?
My Feedback: (17)
ID
for a first 3d plane buy a ca model funky 40 this thing is solid. no wing rock i did my first true harrier with this plane. walls blenders elevators hovering it is all easy with this thing. worth checking this plane out.
My Feedback: (17)
ID
never flown the widebody. but the funky is such a floater, mine has never snapped on me , and i have rang it out very hard. you would not be dissapointed. i think i will have to buy a widebody 40 just to see how it flies. i am also impressed with the seduction planes made buy piliot.
ORIGINAL: lamborghini
As I said the plane has potential but personally I would not buy one. I'd rather stick to my profiles which I know for a fact are capable.
i personally don't like profiles.
you know that by seeing them or flying them ? even the widebody wont do 3d ?
i asked about those plane because i am looking for a first 3d which also could be a nice mini imac
ORIGINAL: zetor
None of those planes you mentioned in your first post are going to 3d worth a crap.
its important to me so can anyone help me with that ?
i want a small scale 3d which could also be a mini-imac, i liked the widebody 40 so can it do 3d ? i also liked this giles http://www.espritmodel.com/l_giles2023d.html but i dont belive it can be a mini-imac. i also liked the ca models epsilon but i dont know if he can be a first 3d.
Go to www.mini-iac.com for the rules. I think you can fly the giles because im gonna fly the Funtana .40 in Basic class.
maybe he is mini-imac legall but it doesn't mean he will be good at this, thw widebody seems like he will be better for imac than the giles
