RCU Forums - View Single Post - BME Edge?
Thread: BME Edge?
Old 07-30-2004 | 08:32 AM
  #163
Airo-RCU
My Feedback: (16)
Default RE: BME Edge?
Hi;How I got my WH-Edge to 16.2 lbs DA-50 With slimline pitts muf. Carbon fiber wing tube,landing gear, and wheel pants, and tail wheel. One reciever, two Jaccio reg. Powerflite lith 2000 on ignition, 2400 on reciever. One JR-8611 pull-pull on rud, two JR 8411 one on each wing, and two JR 8411 on each elev half. Two lite weight 3 1/2 wheels. No pilot or inst. panel. Used all Nelsons hardware. The DA-50 is an awsome engine its lite and gets stronger w/each gal and very smooth.I am using 22-10 NX prop, I just ordered a NX 24-8 this will improve proformance even more. This plane was out of the first batch delievered bought through Tom at WH. My CG is at 4 3/4 from leading edge of wing. I would like to set up a BME this way, I think this compenation would be awsome. Good luck everyone. I"ll be waiting for the first flight report.
ORIGINAL: Scoubidou
Airo-RCU
Can you give us a quick hardware list describing how you can weight 16.2lbs on your WH Edge please and how does it balance to the CG? When did you buy it? It would help to select the right hardware stuff for the BME Edge.
(Out of topic)
I am flying the Extreme Flight Edge 540T for 2 months and it's amazing to see what can do this small plane! Inverted climb flat spin at full throttle with an OS46FX and tower muffler and hover at half throttle...
Futhermore, Chris give a first class customer service!
