ModelTech Extra 300 .36 Pictures
I just finished this ARF and thought I would share the photo's. I would highly recommend to anybody building this plane that you replace the wing bolts with nylon bolts. I installed the blind nuts and small metal screws that came with the kit. Well, one of the blind nuts came loose and I ended up having to drill the head of the screw off to remove the wing.
I installed a Magnum .36 with a MA 10x5 prop. Maiden flight is tonight. I hope it stays in one piece.
