RCU Forums - View Single Post - Hand held starter ???
Old 07-30-2004 | 08:25 PM
PhaedruS's Avatar
PhaedruS
Default RE: Hand held starter ???
I asked a question similar to this not long ago. I never even found the right wheel for it.
To help with your question: I'm pretty sure that the cone adapter on the starter should be replaced with a car adapter that will properly hold the starting wheel.
2 other points to help you out: The wheels are more often referred to as starting donuts, and they are much more common in 1/10th scale. You might try polling those forums for more info.
Now for me:
Has anyone tried the Sullivan Tiger Drive backplate for a 90 degree starting angle on their buggies?????? I am torn between this and a roto start system.
