RCU Forums - View Single Post - Beginner Flight box advice.
Old 07-31-2004 | 08:01 PM
TimC's Avatar
TimC
Default RE: Beginner Flight box advice.
Pull the rubber insert from the starter motor. Check the nut that holds the drive hub on to make sure it's tight. Snug it up good after applying a dab of Loctite. ( My Hobbico takes a 10mm socket ) Also you might try using your car battery to see if that will spin the engine. This will tell you if your flight box battery is bad.
