RCU Forums - View Single Post - funtana 40 elevator problems
Old 08-01-2004 | 08:44 AM
bentgear
Default RE: funtana 40 elevator problems
jb, just how much are you pulling back and how much movement at the surface do you have? If something is warped you should be able to visually detect it just looking at the elevator halves. What it sounds like is a lot of throw and and a hard pull stalling the plane and causing a snap. If thats the case you may be seeing the normal behavior of the plane.
Ed M.
