RCU Forums - View Single Post - Do I need to pump a Saito FA100 ? ? ?
Old 08-01-2004 | 09:57 AM
blademan7065's Avatar
blademan7065
My Feedback: (15)
Default Do I need to pump a Saito FA100 ? ? ?
I am finishing a Tai-Ji 60. I will be using a Saito FA-100. I would really like to put the tank over the CG. The only question is will I need to run a pump? From the nipple on the carb to the front of the tank is 10 inches ? I don't want to make any mods after I put something together if it can be helped. Has anybody tried this set up before or something similar. How far is too far to draw fuel with this engine? If a pump is the answer, which one should I use?
