RCU Forums - View Single Post - Dave Patrick super cub
Old 08-02-2004 | 07:37 AM
  #80
Brylee
Default RE: Dave Patrick super cub
Dick and everyone
A couple of stupid questions if you don't mind.
1. Are you concerned with using CA on the horizontal stab as opposed to epoxy. I'd rather use the ca it's eaiser to deal with then epoxy but I was concerned about strength.
2. I have the Dubro wheels. Is there any trick to drilling them out for the Cub axles? And what bit would you use?
3. You need to be AArrrnold to get the gear to flex. What do you suggest to loosenen them up?
4. Finally and most important (and most stupid) I'm not sure which airlerons go on which wing half. No matter which way I put it on there doesn't seem to be enough throw as per the manual.
