Tower Uproar.. good fun fly?
Hey Dave,
Uproar is a fun airplane. I got one with an OS46fx. Turns 11.5x4 at nearly 13k. Weights just under 4 pounds. Goes vertical 'til out of sight.
Does a pretty good inverted flat spin with the the cg toward the rear. Square loops are okay but not spectacular with the throws I got. Throw in a lot of aileron and rolls are pretty quick.
I'm using 2 ailleron servo's with about 40% flaperon mixed in.
Slows down good with the flaperons on and high rate 'bout 40 degrees elevator.
I should have built mine with about 1/2 in of rudder surface added
to the tail. It knife edges pretty good with about 40deg of rudder but that's about allI have.
Today I was doing knife edge snaps and continuing course pretty good.
Kit builds easily with good instructions and plans with pretty good wood and hardware.
Keep it light and you'll have a good fun fly plane for 40 bucks.
________
DoubleD
