Go Back  RCU Forums > RC Airplanes > Profile and Fun Flying Planes
Tower Uproar.. good fun fly? >
Profile and Fun Flying Planes If you're a profile fan or into fun flyers than this is the forum to discuss those topics.
Old 07-23-2002 | 01:35 AM
My Feedback: (17)
Default Tower Uproar.. good fun fly?
Tower has lowered the price on the Uproar 40 to an attractive $39.99. Anybody have feedback on this kit?
I've got an extra Tower .40 engine lying around - would this be a good fit? 11x4 prop, 10x5 or 10x6?
How fast a build is it? How does it fly?
Dave
Old 07-23-2002 | 03:09 AM
Hey Dave,
Uproar is a fun airplane. I got one with an OS46fx. Turns 11.5x4 at nearly 13k. Weights just under 4 pounds. Goes vertical 'til out of sight.
Does a pretty good inverted flat spin with the the cg toward the rear. Square loops are okay but not spectacular with the throws I got. Throw in a lot of aileron and rolls are pretty quick.
I'm using 2 ailleron servo's with about 40% flaperon mixed in.
Slows down good with the flaperons on and high rate 'bout 40 degrees elevator.
I should have built mine with about 1/2 in of rudder surface added
to the tail. It knife edges pretty good with about 40deg of rudder but that's about allI have.
Today I was doing knife edge snaps and continuing course pretty good.
Kit builds easily with good instructions and plans with pretty good wood and hardware.
Keep it light and you'll have a good fun fly plane for 40 bucks.
________
DoubleD
Old 07-23-2002 | 04:09 AM
Tom Nied's Avatar
Dave,
Did you take a look at the Adobe PDF file Tower has on the Uproar's assembly manual? It might give you a better idea of what goes into the assembly process. Wing area is 573 inches. Looks like a Tower 40 would be a fine match, if its running good for you. Unless you want a rocket. I've ordered a Fun 51 , and I'm also trying to decide what motor I want to use, either a TT GP-42 or a TT Pro-46. Guess it depends on just how much power you want on hand. I'm thinking a plain bearing 40 will still be a whole lot of fun. Then there's the problem of when the plane is "cashed", what are you going to want in the next plane. If its a smaller plane again like the Uproar, no problem. Just one interesting note, I learned to fly and flew a Sig Kadet Senior using a TT GP-42. Wing area 1150". Had lots of fun, going slow. I think a regular 40 in these planes is what they were designed for, why not use them. Tom
Old 07-23-2002 | 08:20 AM
Don't bother with the Tower 40 (or any other brushing 40 sized motor), step up to a good/powerful BB 32-39 engine (I chose the TT Pro-36) and let 'er rip! Mines come out to the field with me every time I fly since I got her built (it's about 2 months old now). I had a TT GP-42, but it didn't give the 3.75lb model unlimited vertical, so I swapped in a Pro-36 and can hang on the prop and power out!
BTW, few planes can match the Uproars low speed flying capabilities.
Old 07-23-2002 | 01:45 PM
Tom Nied's Avatar
"or any other brushing 40 sized motor" What's a "brushing". Is that a new manufacturer?
I don't know, power specs for the Pro-36 and the GP-42 are the same. I really wonder if there's much difference.
Pro-36 is $80 GP42 is $52 I see a $28 difference
Depends what you want, all the "oomph" you can put in that plane or an excellent use of a Tower 40 that's not being used.
If its running good, I think it would be a "good" fit.
Old 07-23-2002 | 03:02 PM
I've got two GP-42s and one Pro-36 and you can't always believe what the manufacturer's claim as power... The Pro-36 is a little monster engine capable of power equal to most BB 40 sized engines, yet weighs 11 oz. It's TT's converted heli and the only true ABC engine in their stable (all the others are ABN I believe). I've only got about 10 6oz tanks through this engine, it's already turning 14k+ with an APC 10x5 prop running rich on 15%! Neither of my two GP-42 come close... Mine is currently flying with an APC 11x3 prop and it hovers SIGNIFICANTLY better with the Pro-36 than with the GP-42 using the same prop.
Don't get me wrong, I think the GP-42s are great engines, there's no better for the cost. And compared to my 40LA and the Tower 40 that I've seen at my field, they make at least 10% more power and are much more reliable, but the Pro-36 makes about the same power of a BB 40 which should make 10-15% more than a brushing of the same size.
Do some searchin' on the Internet and you'll find that the Pro-36 is a favorite amoungst fun fliers! In fact you'll find that most people consider this $75 engine in the same class as the $120+ OS 32SX and Webra 32 Speed GT.
I had fun with the GP-42 in my Uproar, but now that the Pro-36 is in it, I'm having a BLAST!
Old 07-23-2002 | 03:17 PM
Tom Nied's Avatar
Yeah f2racer, I hear you. The Pro-46 weighs 17oz. The Pro-36 sounds like its a real screamer, like its big brother the 46. I've had such good service from the GP-42 that I don't even know what comparable 40's are like. So now you got me goin, "hmmmmmmmm".
Let me ask you, did you have to add any nose weight?
Sometimes that consideration helps one decide a engine/plane combination.
Old 07-23-2002 | 04:14 PM
My Feedback: (17)
Thanks for the feedback guys.
I have a pair of TT.36PROs in my Twinstar. They are much friendlier, more reliable and stronger than the Tower .40... but my Tower .40 runs ok and is collecting dust... so....
I'm excited to try some slow flyin stunts on the cheap.. Sounds like the Uproar is a winner for $39.99.
Thanks again.
Old 07-23-2002 | 04:26 PM
m.gramling's Avatar
My Feedback: (8)
Its hard to beat a 39.95 kit. Just built it light, and you will have a blast. If your using the TT36 or 42 you will want to keep this plane under 3.75lbs. To have good vertical climbing. If you can figure out how to get this plane at 3.5lbs even better.
Old 07-23-2002 | 04:52 PM
Actually if you build the plane with the servos and radio gear where the plans indicate and use an 11-12oz motor, you'll have a plane that is more or less perfectly balanced. My Pro-36 (11.5oz) is mounted as close as possible to the firewall, which moves the CG back between 1/8" and 1/4" from the location shown on the plans. A 15-16oz 46 will either require some weight out back OR relocated the RX/battery and possibly the servos out to the back of the fuselage to balance properly.
The Uproar is a great flier, I can fly mine (3.75lbs) at a crawl. I wouldn't be too concerned about weight with this model. Even 46 powered Uproars come out to about 4lbs.
