RE: Dave Patrick super cub
Dick Thanks for the help. The Dubro wheels drilled out just fine.
I am planning on putting in a 150 side mounted as per the instructions. Any thoughts on a muffler. I was going to go with the slimline pitts ($89 ouch) but what the hell.
A couple of other questions if you don't mind. I usually fuel proof the inside front of the fuse where the tank goes. Are you doing this?
Also do you find that the slots for the horizontal and vertical stabs rudder and elavators are shallow and need a lot of "openning".
BTW your cub looks great. Good luck.
