RCU Forums - View Single Post - Best Cerroplast glue
Old 09-09-2002 | 03:31 PM
gunfighter
Default Best Cerroplast glue
Lots of methods will work. Welder glue and goop are popular.
However, If you want the strongest joint -
1. flash the coro,
2. use a "woodpecker" to punch tiny holes in both sides to be glued
3. put small drops of CA about 1/2" apart on 1 side,
4. dampen the other side with a wet paper towell or mist with a spray bottle,
5. Clamp or weight the pieces for at least an hour.
These pieces will not ever come apart!
Twister2 - Where in OK. are you? I'm in the south. E-mail me.
