I didn't change a thing. I took Chip's advice and kept the cabane bolts loose and dry fit the struts. The bottom wing is "set" by design and the top is set based on the struts and cabanes.
By keeping everything loose til I drilled the strut holes it allowed the top wing to settle where it should be. I have yet to check where that left the incidences, but I guess I didn't have to...
The only snapping I found it to do is in a tight outside loop... it will trun out of it but not scarily.
Right now I just want to get the engine broke all the way in and settle in on the final prop... maybe a Mejzlic 22x10 or 24x8...
Then I intend on really going to pains to tweak this one to it's best....
If they never made another plane, I'd be perfectly happy with the DV and Yak...
