RCU Forums - View Single Post - Successful flights
Old 08-06-2004 | 12:48 PM
peso
Default RE: Successful flights
I use a Hitech 545. The weight of the machine is about 4 pounds so it is lighter and smaller than the Kellets. But maybe the servo is not strong enough. And the pushrod could definitely be made stiffer.
I will replace the pushrod and also try to rebalance the rotor. If it does not help I will try a stronger servo.
/PO
