ORIGINAL: volkan
and most probably more power
the 3151's have the same power (43oz) as the 3004, so you only really get speed, resolution, and centering.
edited this in for compairison.
S3151
SPECS: Speed: 0.21 sec/60 degrees at 4.8V
Torque: 43.1 oz/in @ 4.8V
Dimensions: 1.59x0.79x1.42 in (40.6x20x36mm)
Weight: 1.48oz (42g)
S3004
SPECS: Speed: 0.23 sec/60 degrees at 4.8V
0.19 sec/60 degrees at 6.0V
Torque: 44 oz/in (3.2kg-cm) at 4.8V
57 oz/in (4.1kg-cm) at 6.0V
Length: 1.6" (41mm)
Width: 0.8" (20mm)
Height: 1.4" (36mm)
Weight: 1.3 ounce (37.2 grams)
Connector: "J" type with approx. 5" wire
