RCU Forums - View Single Post - 9CAP Programming Help
Old 08-07-2004 | 09:38 PM
cougar347's Avatar
cougar347
Default RE: 9CAP Programming Help
O.K., now I feel stupid again. I've been fooling around with this thing all evening. I can get spoilerons to work off of PROG.MIX6-no problem. I can also get flaperons to work off of PROG.MIX6 by reversing the numbers. I was hoping that I could run both flaperon and spoileron mixes off of the same program by just changing the switch position. Doesn't seem to work that way. My problem is that I can't find another PROG.MIX that will allow me to put spoilerons on PROG.MIX6 and flaperons on the other. My goal is to have spoilerons and flaperons all off of switch C, the three position switch. Up would be flaperons, neutral is neither, and down would be spoilerons. Is this possible to do? What am I missing? Which Program Mix do I need to use for flaperons? None of the other program mixes seem to have the same layout/parameters as PROG.MIX6.
Vince
PROBRO #222
