RCU Forums - View Single Post - GT running problems,I am stumped
Old 08-08-2004 | 04:51 PM
nitrodude90
Default RE: GT running problems,I am stumped
ORIGINAL: HARLEY69
It will start fine only if I add fuel down the carb. There is no fuel going to the carb. There seems to be more fuel going to the pipe then thru the fuel line. What's up wit dat. It's not mine but is like new. Carb set to stock specs,so I can start over. All fuel lines changed. The tank has no leaks. I just can't figure it out and need some HELP. It's all stock,even the engine and like I said, it's like new. Any help at all would be great. Just need some more place's to look. There is no air leaks that I can find. Thanks
make sure you didnt get the fuel lines mixed up
