RCU Forums - View Single Post - what type of charger will charge these batteries
Old 07-25-2002 | 01:20 AM
greenboot
Default what type of charger will charge these batteries
The best way to determine how many flights you can safely get is by measuring the voltage at the beginning and end of each flight. Do this a couple of times until you get a "feel" for how much capacity you actually use for each flight. I can't tell you how much it will be since it depends on the type of plane and the length of each flight.
You should also construct a chart of battery voltage over time while you discharge the battery with a known load. Note what voltage the plateau occurs at. Also note the voltage where the batteries drop off rapidly. Don't start a flight unless you have enough capacity plus a generous reserve.
If this sounds like a lot of work, just use a field charger after 3 flights to peak them. That's what I usually do. It gives me a chance to BS a little bit.
Tom
