RE: Run time and deadstick
Diamonds, you know, you could be right. I've filled tank before and when the breather silicon tube leaks fuel, tank is filled but, when I look at tank, its actually not full. I will have to double check it. And also, I will have to check about the richness. I do have a tachometer
so I will do a check on the engine too. Thanx for the tippo....geez, I'm constantly learning on this glow stuff all the time.
Thanx Wood. I dead stick all the time on my electrics. I just keep flying until the batt runs out and then land as close as I can to
me feet. All my electrics are belly landers.
