Run time and deadstick
My Feedback: (18)
Lucky Armpit, back to your original ? A lot of times fuel consumption depends on your dlying. I have a profile that has a 4oz tank and a TT pro 46, the plane is super light. Execpt when doing a manuever, I fly it just above idle most of the time and I can get an 11 minute flight.
I dont have a problem with flying till deadstick either. When I know I am out of fuel I just go a bit higher in order to give myself plenty of working room. I wouldnt call it irresponsible.
As far as keeping you rnose down with a deadstick, I think it helps you from stalling out. If you have the nose up and a wind gust comes by, the plane balloons and then can stall. Keep the nose down and flare right before landing. Its important to know the tendencies of a plane and when it stalls so that you can do this.
WI
Maybe you should take some of the fuel left after landing and drown that bug up your... never mind....
