RCU Forums - View Single Post - radio problems!!
Old 08-09-2004 | 06:49 AM
Matt Kirsch's Avatar
Matt Kirsch
My Feedback: (21)
Default RE: radio problems!!
If it worked in the hummingbird, then it's highly unlikely that ANYTHING is broken, unless of course you dropped, smashed or mangled something during the transfer.
Make sure the servos are plugged in correctly. If you plug them in backwards, they will glitch like that. Re-seat the crystal. Try disconnecting the main battery and using a standard receiver pack if you have one. Try powering the receiver from the hummingbird's speed control.
IIRC, the Hummingbird has an el-cheapo radio option that's a cheap AM unit. Are you sure it's "Futaba compatible" as in FM? Are you using the Hummingbird's receiver, or did you buy an additional one?
If any component needs replacing, it can be purchased separately. You can custom order a radio set with just the transmitter from most hobby shops.
