RCU Forums - View Single Post - WHEN LI-POLYS GO BAD??
Old 08-09-2004 | 07:17 AM
Matt Kirsch's Avatar
Matt Kirsch
My Feedback: (21)
Default RE: WHEN LI-POLYS GO BAD??
12 to 20 minutes means an average of 3-5C, which on the surface is well within the capability of TP2100s. The real issue here is maximum current draw, and how much you used it. IIRC, TP2100 packs have a rating of 6C, or about 12 Amps. If you have a power system that draws more than that, you could be damaging the cells.
Two questions that might clear things up for you:
1. Was the pack that's experiencing poor performance in the plane when the gearbox was binding?
2. What was the second question I was going to ask you? (my train of thought derailed)
The binding gearbox could double the amount of current being drawn by the motor.
