E-Flight Power Sources Ask questions or read about power sources as they specifically relate to e-flight including Lithium-ion, Li-Poly, Nimh and Nicad battery packs.
WHEN LI-POLYS GO BAD??
Old 08-08-2004 | 05:32 PM
Default WHEN LI-POLYS GO BAD??
I am using 3s 2100 thunder power li-polys and am getting flight times of 12 to 20 minutes depending on throttle. Except one pack is now lasting maybe 5 minutes. It charges fine and after power drops off (about 5 minutes) and landing the battery still reads 11.6 volts but not enough power to fly. Is this what happens to polys? Could it be from over drawing the pack? I did bump the gear shaft and didn't notice it was binding one time until I landed and flipped the prop. Thanks for any reply
Old 08-09-2004 | 07:17 AM
Matt Kirsch's Avatar
My Feedback: (21)
Default RE: WHEN LI-POLYS GO BAD??
12 to 20 minutes means an average of 3-5C, which on the surface is well within the capability of TP2100s. The real issue here is maximum current draw, and how much you used it. IIRC, TP2100 packs have a rating of 6C, or about 12 Amps. If you have a power system that draws more than that, you could be damaging the cells.
Two questions that might clear things up for you:
1. Was the pack that's experiencing poor performance in the plane when the gearbox was binding?
2. What was the second question I was going to ask you? (my train of thought derailed)
The binding gearbox could double the amount of current being drawn by the motor.
