RCU Forums - View Single Post - what are the basic equipmant for a new beginner?
Old 07-25-2002 | 01:03 PM
jharkin's Avatar
jharkin
Default what are the basic equipmant for a new beginner?
highness-
In answer to your question:
1. Depends on whether you are building a kit or assembling an ARF. In either case its good to have a basic selection of glue (thin ca, medium ca, 5/30 min epoxy, maybe carpenters glue), an x-acto knife, Phillips head and straight screwdrivers, and a set of Allen (hex) keys.
2. To start the engine you need the proper glow plug (good to have a spare), a glow plug wrench, a glow plug igniter battery (the simplest are the ni-starter style), fuel, a pump to get the fuel in your plane, and something to flip the prop (either a chicken stick or electric starter and battery). NEVER flip the prop by hand to start.
3. The most basic field set would be the equipment in #2, plus whatever simple tools may be need to make adjustments at the field (usually the screwdrivers and Allen wrenches). You will also need rubber bands to attach your wing if its not held on with bolts, and something to clean off the exhaust residue (I use glass cleaner and paper towels).
-Jeremy
