RCU Forums - View Single Post - Hyper 7 Suspension - Problem?
Old 08-10-2004 | 03:33 AM
mk999's Avatar
mk999
Default RE: Hyper 7 Suspension - Problem?
Preload is the little clips that you put on the suspension. I am surprised you managed to use old oil did you fill them to the top? I have been recommended by a very reputable source 35wt in the rear and 50wt in the front with 1.5mm drilled pistons for a bumby dusty low grip track and it's bumpy as well, oh and don't forget the bumps
