AW 25% Edge
Reid,
I have this plane with a Saito 150. The plane weighs 9 1/2 lbs.
This motor is way more than enough. Unlimited vertical. I saw one once with a 3W-24 in it. I thought it was overkill.
Great building kit. You'll need to reinforce the landing gear mounting area. Especially if flying off grass. I also added flying wire on the tail.
If you really want gas, I would look into the RCS 1.4 or 1.8. I'm not sure about their power, but they should be plenty.
As for the 2 servo wing option, not needed on this size kit.
I did put 2 servos on the elevator and pull pull on the rudder.
A picture of my plane is on the Aeroworks web site with the Millionair scheme.
