AW 25% Edge
AW 25% Edge
Hi! You guys have me very interested in this Aero Works 25% Edge. I'd like a little more information on it. How are AeroWorks kits? They seem to be of Carden cailiber, but I haven't seen many of their planes at shows etc. Does anyone have any good engine recommendations for this airplane? I'd like gas, and would like to stay away from Zenoah. Does Brisson make an engine this small? What's the "2 Servo Wing Option" that's available along with the builder's kit? I'm just looking for more information than what's available on their rather mediocre website.
Thanks!
Reid
Thanks!
Reid
AW 25% Edge
Reid,
I have this plane with a Saito 150. The plane weighs 9 1/2 lbs.
This motor is way more than enough. Unlimited vertical. I saw one once with a 3W-24 in it. I thought it was overkill.
Great building kit. You'll need to reinforce the landing gear mounting area. Especially if flying off grass. I also added flying wire on the tail.
If you really want gas, I would look into the RCS 1.4 or 1.8. I'm not sure about their power, but they should be plenty.
As for the 2 servo wing option, not needed on this size kit.
I did put 2 servos on the elevator and pull pull on the rudder.
A picture of my plane is on the Aeroworks web site with the Millionair scheme.
AW 25% Edge
What is the 2 servo wing option? Is it just what it sounds like? - 2 Servos on each wing? Why would that be more expensive anyway? That's a great looking plane you've got, is it a Saito 150, or a Saito 180? 180 is listed on the website, but you just mentioned a Saito 150. Thanks for your info!
Reid
Reid
AW 25% Edge
It's a Saito 150. You might be looking at the wrong plane. Mine is Red and White with the Million Air decals on it. Middle of the 7th row of pictures down.
You're right about the 2 servo option. 2 aileron servo's on each wing. I guess they charge for the labor of making that extra cut out.
