ORIGINAL: DJevader
Thanks ALOT I really think this is my problem. And I do see air bubbles in my fuel line before it stalls!? After working on this for two weeks I was ready to send this thing into the shop and have them deal with it, because it is still under warrenty.Is this going to be complicated or expensive to repear ? Should I still send it in ?
Thanks soooo much,
DJevader
Try this first. Get some new fuel line; not that cheap stiff crap either.... replace all of your lines and use small tie-wraps at EVERY line end (e.g. at the carb inlet, fuel outlet from tank, BOTH sides of your fuel filter if you have one inline) and see how it does. If you see bubbles coming from the carb after it goets hot those bubbles will further lean the mixture causing it to get much hotter much quicker...
