RE: Motor Problems
Well, I've figured out what I'm going to do, and I assume it will work. First, make a wire harness, connect red with black, then the other black and red connect them to a connector, then hook it into one of the supplys to give it the full 14.4 volts. (because the speed control works with one battery plugged in)
