RCU Forums - View Single Post - GT running problems,I am stumped
Old 08-11-2004 | 09:26 AM
HARLEY69
Default RE: GT running problems,I am stumped
Just letting you guys know I got it running. I did 2 things. 1- I moved the pressure fitting to just under the lid,didn't make much sence where it was. I also re-adjusted the carb. Now it starts and there's not much fuel going thru the pressure line. I think that was the big problem. Why did they put the pressure line on top of the tank, in the middle with a tube running to the bottom on the tank? I never seen one run that way. I just blocked that one off and drilled a small hole just under the lid on the side and put a small brass fitting there. Work's great and runs forever. Now I can give it back to the owner. Thanks for the help.
