Screws
Some are peened over, some have one way bumps on the screw, some have lock washers..If in doubt use a small lockwasher and Loctite..I use green 680 shaft and bearing mount Loctite..The screws are cad plated brass..The head will twist off before the Loctite lets go...The more common types of Loctite should work almost as well....
