RE: Modified Hotspot
Now with a decent digital camera, I am posting some less crappy pictures of the Hotcat. We are having a ball here with this plane, absolutely a joy to fly. The only problem found on this plane is the hours spent fiddling with the landing gear. Even on the most greased on landings, the legs get a little bent, and then we have to spend time on fixing it. This problem
was apparently solved with the addition of a rubber strip under all the gears. This rubber apparently makes the leg a less rigid structure, so, it can bend a little without damaging the gear mechanics. (so far).
Rgds, Enrique
