RCU Forums - View Single Post - Walmart Sub Again!
Old 08-13-2004 | 03:07 PM
red91sit
Default RE: Walmart Sub Again!
I found the balance pretty easily as long as the water level resting is somwhere on the conning tower it seems to work fine. It works best if its' kinda nose heavy or you angle the front hydroplanes? down a bit. The motor pulse thing when going backward is normal it works better if you pulse the reverse motor yourself quickly.
