ORIGINAL: seanreit
You can also heat it a bit and slip a credit card or something in there and lift it clear. It will cool to form.
I did both the sandpaper and the heat method. Use a credit card like Sean says and you just want a small drop in it. I wish I would have just used the heat method in the first place. Now the gap is bigger from the sanding.
