RCU Forums - View Single Post - Another Engine Question!!!!
Old 08-16-2004 | 04:50 PM
CougarRules's Avatar
CougarRules
Default RE: Another Engine Question!!!!
ORIGINAL: ui_fearmaite
When adjusting the low end needle valve should the adjustment be made with the throttle open or should the throttle be closed to the idle position, or does it make a difference.
No it makes no difference whatsoever. But the high speed needle should be adjusted with the engine running at full throttle.
