RCU Forums - View Single Post - WM Extra 300 160
Old 08-16-2004 | 10:09 PM
ooooo's Avatar
ooooo
Default RE: WM Extra 300 160
Hi tIANci......this is truly a nice plane. Looks good in the air also and does anything you ask it.
The MVVS 35 is a good engine for this plane......I have a Fuji in mine and it flies great with that engine. Just build according to the manual and you will be fine. Check your CG....set 40% and 70% for lo and hi rates and you will be fine. Take off with lo rates ) and turn her into a beast in the air with the hi rates.
Cheers.
