Select a propeller that will allow the engine to turn in the high 10,000's on the ground. Any prop that will allow the engine to turn that RPM and fly the model the way you want is the correct one.
Since we've not done much in the way of 3D-type work, we're only used to standard type props. We usually run an APC 13x8 prop in our tests. We've seen them turn in the low 11,000's at times, if the engine's been broken-in very well.
If you have to reduce the pitch, then up the diameter. Keep the RPM in the suggested range for best throttle handling.
We hope you find this information helpful. Should you have any further questions or concerns, please do not hesitate to contact us at this email address. (Please be sure to copy all previous emails into any future questions.)
DID YOU KNOW that our web pages now all contain FAQs? (Frequently asked questions) Please drop by and take a look! We hope you'll find the information helpful and valuable to you.
Sincerely,
Bill Baxter, Manager
Hobby Services
1610 Interstate Dr.
Champaign, IL 61822
USA
Phone: 217 398-0007
Fax: 217 398-7721
Email:
[email protected]
Web:
http://www.bestrc.com
