9c 3D setup Ques
On the 9c For extreme 3d throw can I use the ailerons to act like spoilerons when I pull the elevator stick past a certain point? i.e. elevator channel as the master, and the flap as the slave (you're already using flapperon mix for the two aileron servos). Set a curve so the ailerons don't move until the elevator stick is about 75% toward the stop in each direction. How would I do this
