9c 3D setup Ques
MA
On the 9c For extreme 3d throw can I use the ailerons to act like spoilerons when I pull the elevator stick past a certain point? i.e. elevator channel as the master, and the flap as the slave (you're already using flapperon mix for the two aileron servos). Set a curve so the ailerons don't move until the elevator stick is about 75% toward the stop in each direction. How would I do this
You need to use either mix 6 or 7 which are 5 point mixes. Keep the middle 3 points set to zero but make points 1 and 5 the percentage of spoilers you want. This is called snap spoilerons as they only come on after 75% of stick travel on the elevator. Hope this helps.
Tom
Tom
