RCU Forums - View Single Post - 9c 3D setup Ques
Old 08-17-2004 | 12:19 AM
stang281472
Default RE: 9c 3D setup Ques
You need to use either mix 6 or 7 which are 5 point mixes. Keep the middle 3 points set to zero but make points 1 and 5 the percentage of spoilers you want. This is called snap spoilerons as they only come on after 75% of stick travel on the elevator. Hope this helps.
Tom
