RE: Dave Patrick 26% Extra 330L
I am interested in knowing if you used two servos per aileron or just one - and how much torque used per aileron.
I have had this plane for awhile but have not started putting it together due to many reports of aileron flutter.
This plane seems to suffer from an unusual paradox: if you put in the recommended motor - you come out tail heavy....
If you put in a gasser - you achieve proper CG but may tear out the ailerons.
I am thinking of using an RCS Roto 35....or should I go with a 40cc?
