RE: Errors in Seagull Spacewalker II manual
Aaah again. Memory...coming...back. Slowly. On the section describing the mounting of the cowl we are told to use the marks we had made earlier at the location of the mounting blocks. Well that whole section of the text and instructions is apparently missing! And upon inspection so are the mounting blocks!!! There does seem to be some block in approximately the right location for the bottom screws but there are definitely no blocks were the upper screws would go. But then this shouldn't really be a problem because the location is made of 1/8" ply so it should hold up.
All in all this seems like a case of "Don't RTFM!" Too bad for such a great model to have such sucky instructions.
