RCU Forums - View Single Post - Ordered AFP!!!!!!
Old 08-21-2004 | 01:01 PM
  #58
Stein
Default RE: Ordered AFP!!!!!!
Go to here on your C: drive C:\Program Files\IPACS\AeroFly Professional\config and open up the Main file in notepad and you will see the information below (I just copied some not all here so you can see whet it looks like):
cloud_type 81
smoke_color_red 0.00000
smoke_color_green 1.00000
smoke_color_blue 0.00000
smoke_density 1.00000
exhaust_density 1.00000
I put the line you are looking for in bold, change the 1.00000 to 15.00000 or what ever you would like I changed mine to 25.00000 and it was way too much smoke could not see to fly try 15 and then change it from there. When you change the number then save it and close it down and thats it. It will slow your computer down some but not alot depends on how fast your computer is.
Brian
p.s to open file double click and pick select program to open from list then click ok and pick notepad to open it and then change the number. If you want you can uncheck the box that says !QUOT!Always use selected program to open this type of file!QUOT! It does not matter if you do or not will work both ways.
